Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Slow down of a mechanical simulation after restarting › Reply To: Slow down of a mechanical simulation after restarting
April 1, 2024 at 11:06 pm
Hi Gary,
I cannot access the image you uploaded. Could you upload it again?
Currently, I call structural simulation via System coupling, so my job submit file only specifies a number of node for system coupling and it automatically assign the same number for structrual, fluent, and system coupling. I attached a screenshot of my submit file:
and the corresponding generated output file that calls mechanical is below:
Is there anyway I can pre-set it in workbench before I export the system coupling setting?
Thanks!
Eric
