Ansys Learning Forum Forums Discuss Simulation Photonics Source to model light extraction from an omnidirectional LED Reply To: Source to model light extraction from an omnidirectional LED
Guilin Sun
If your LED is layered, thin-file type, I would suggest to use stackdipole:
stackdipole - Script command
FDTD vs stackdipole - halfspace emission in a multilayer stack
Usually it uses dipole source for simulation, and average the results with 2 or 3 dipole sources separately, depending on if the LED has symmetry.
Please refer to this example  Micro-LED
