Ansys Learning Forum Forums Discuss Simulation Photonics Method to add Lithium Niobate Material in Lumerical Charge (Device) solver Reply To: Method to add Lithium Niobate Material in Lumerical Charge (Device) solver
Guilin Sun
As long as you know the materials belongs one of the three categories: insulator, metal and semiconductor, you can create new matgerials in CHARGE:
Semiconductor Material Model Properties
Tips for creating a new semiconductor material
Electrical/Thermal material models in CHARGE, HEAT, and MQW
Thin Film Lithium Niobate Electro-Optic Phase Modulator
/forum/forums/topic/charge-creating-sio2-semiconductor/
metals and insulators have much fewer parameters so you can follow the same procedure to add them.
 Since CHARGE simulates only the semiconductor materials, sometimes you will need to convert insulator/metal to be semiconductor by assign proper semiconductor material properties.
