Ansys Learning Forum Forums Discuss Simulation Fluids Help with Battery MSMD model Reply To: Help with Battery MSMD model
Murari Iyengar
Hi Harsh,
  1. You have 2 options the ECM model, to use 4P model (1 RC) or 6P model (2 RC). If you want to use higher RCs, this will require you to write a UDF with all the battery related equations.
  2. In the newer versions, UDS Diffusivity is changed to Electrical Conductivity. In the sub-options, you can choose Defined-per-uds.
