Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Analysis of Robotic Finger › Reply To: Analysis of Robotic Finger
March 30, 2024 at 9:38 pm
ROHITH
OK THEN MODELLING THE STRING IS THE PROBLEM IN THIS CASE. IF I COULD DRAW THE STRING WITH ALL THE CONSIDERATIONS YOU MENTIONED THEN IT WOULD SOMEHOW BRINGOUT THE RESULT, RIGHT. BY ANY MEANS COULD YOU JUST MODEL ONE STRING AND SOLVE THE PROBLEM IN WHICH THE STRING SLIDE AROUD THE OUTER CORNER WHERE IT BENDS IT COULD HELP ME A LOT IN MY TASK AND HELPS ME FURTHER MOVING FORWARD WITH OTHER STRINGS
