Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem when simulating a battery pack with multiple parallel battery connection › Reply To: Problem when simulating a battery pack with multiple parallel battery connection
March 28, 2024 at 2:10 pm
Hi, if your temperature is too low, then I recommend you check your boundary conditions. Apart from temperature, also check your electrical variables to ensure you are getting the right results.Â
