Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with the definition of a path on a curved side › Reply To: Problem with the definition of a path on a curved side
March 27, 2024 at 2:48 pm
Translated:
Hello everyone
I have a problem defining a path on a curved side belonging to a defined surface with "Construction Body" treatment and then simulating a crack using the Ansys Fracture module. The idea is that the crack front is curved to achieve a more realistic model, compared to another model with a straight crack front. In the latter I didn't have any problems because I defined the path by two points. However, the path defined by two points on the curved side is not generated correctly (image 1). I have tried to define the path using the "edge" method instead of using the "colon" method, to do this I have to define a "Named Selection" but it does not allow you to select the side correctly (image 2). Can anyone help me? help?
Thank you very much in advance.
Best wishes
José Gargallo
Figure 1.
Figure 2.
