Ansys Learning Forum Forums Discuss Simulation General Mechanical Structural optimization – adaptive mesh refinement (beta) failure in 2024R1 Reply To: Structural optimization – adaptive mesh refinement (beta) failure in 2024R1
Martin Stejskal
Dear Ashish Khemka,
thank you for your reply. Unfortunately, I am unable to share the geometry in any way. It is a simple, but large FE model of car body of a specific vehicle. There are many nodes (>100k even with big elements) and I need to refine the mesh where the resulting material will be kept,  which is not known beforehand. Even when I tried to reduce the analysis to just having a geometry (without springs etc.), it still wouldn't work and I would get the aforementioned error.
Also, thank you for the post, but I've already seen it and haven't been able to make it work. As I have stated before, the beta feature works perfectly fine on a smaller-scale fea, but fails at my case.
Let me know if there is anything else I can try. Thanks in advance.
