Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Drive the rotation of a crank with parameters in Discovery / Workbench. › Reply To: Drive the rotation of a crank with parameters in Discovery / Workbench.
March 26, 2024 at 11:46 am
Hi Brendan,
Part transform will help to modify the orientation in Mechanical. Can you see the parametrize option for the joint loads like rotation or may be setup an analysis with multiple steps indicating different orientations.
Ashish Khemka
