Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Mesh adaption of cells that are not being marked › Reply To: Mesh adaption of cells that are not being marked
March 25, 2024 at 3:04 pm
Just to be clear, it is a high-speed flow case so the contours should look clean and smooth, especially at the inlet. I'm also using second-order upwind scheme and AUSM inviscid flux type so really, everything should be going downstream. I have a really fine un-adapted case that reflects this accurately.
