Ansys Learning Forum Forums Discuss Simulation Electronics De-embedding port in Ansys Circuit Reply To: De-embedding port in Ansys Circuit
Dan Dvorscak
Not like that on arbitrarty s-parameters. In Circuit, if have the s-parameters of a fixture and a full device under test, you can utialize the "use recirpricol" options to de-embed the fixture from the DUT in a LNA simulation. But that is different than de-embbeding a fixed distince from a wave port. You can make that work, if it is a dynamically linked HFSS project and if you make the demebeeding distance a parameter. In that case, you would be able to change the de-embedded distance by changing that parameter in the Circuit component for the HFSS model.
Best regards,
-Dan
