Ansys Learning Forum Forums Discuss Simulation Fluids 2D conjugate heat transfer Reply To: 2D conjugate heat transfer
If the heat flux is from the plate you'll not beable to do that in 2d, it's a 3d effect. You could estimate the flux to the individual pins and compare the two approaches.Â
