Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Dissolved Oxygen Simulation › Reply To: Dissolved Oxygen Simulation
March 25, 2024 at 9:55 am
Do NOT use ideal gas for liquid properties! It won't end well as there's nothing in the model to assign phase as there's nothing linked to latent heat in the model. It's usually safe to assume liquids are incompressible unless you need buoyancy, in which case read the manual and explain what you think you need to include.Â
