Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › fluid simulation doesn’t work on thin solids Ansys Discovery › Reply To: fluid simulation doesn’t work on thin solids Ansys Discovery
Hello,Â
Please refer Discovery : "Thin" geometric features and relative GPU adjustments article on how capture more detail if you have already turned up the fidelity.
You can also go through Fluids Simulation, Local fidelity|Ansys Course where you will learn about local refinement in Explore-Mode for fluid simulations. Also, Fluids Simulation, Discovery Cutter bodies|Ansys Course provides information on Cutter bodies which enable the generation of bulk fluid volumes and the designation of overlapping solid bodies or dirty CAD, as cutters, without the need for traditional Boolean operation.Â
Let me know if these help.Â
Thanks,
Devendra
