Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Need micromovement in X, Y and Z directions › Reply To: Need micromovement in X, Y and Z directions
March 21, 2024 at 10:01 am
You can use the nmisc values in APDL and write to a file (*cfopen, *vwrite), and use *get command to get node IDs of the elements I,J,K,L nodes.
*get,node_I,ELEM,element_ID,node,1
*get,node_J,ELEM,element_ID,node,2
*get,node_K,ELEM,element_ID,node,3
*get,node_L,ELEM,element_ID,node,4
But I'm not sure how to get the R and S directions for each element in global CS vectors. Elements can have curvature so these may even be different at each node when converted to a global CS vector.
