Ansys Learning Forum Forums Discuss Simulation Photonics – Chinese FDTD多层结构的快速建模 Reply To: FDTD多层结构的快速建模
Guilin Sun
最简便的方法是建立结构组,用脚本添加每一层,每层的厚度和材料都可以设置为变量。我这里有个例子:
脚本
selectall;
delete;
#Substrate
addrect;
set("name","SiO2");
set("y min",0);
set("y max",d_SiO2);
set("material",SiO2);
addrect;
set("name","Si");
set("y min",d_SiO2);
set("y max",0+d_SiO2+d_Si);
set("material",Si);
addrect;
set("name","SiO2_2");
set("y min",0+d_SiO2+d_Si);
set("y max",0+d_SiO2+d_Si+d_SiO2_2);
selectall;
set("x",0);
set("x span",xSpan);
set("z",0);
set("z span",1e-6);
注意,我是在分析组设置的,所以光源监视器都可以。结构组只能设置结构。上面的示例是在
