Ansys Learning Forum › Forums › Discuss Simulation › Fluids › About modelling the tube side flow as a solid cylinder › Reply To: About modelling the tube side flow as a solid cylinder
March 19, 2024 at 4:25 pm
Use Fluent, and zoom in around the baffles. You may need to look at the velocity field too. Possibly compare node values on & off.Â
