March 18, 2024 at 7:22 am
Derrick Rogers
I think you should consider disposing of the .rst file. As you mentioned, it might be worth trying to dispose of the .rst file before performing another solve. You can use an APDL command like /INPUT, filename.rst to read the .rst file and then issue a /SOLU, PREP7 command to reset the solution environment.Â
