Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to know the mass flow rate at outlet surface when using DPM model? › Reply To: How to know the mass flow rate at outlet surface when using DPM model?
March 14, 2024 at 8:48 am
Yes,I think updating is the best solution.????
I use "total flow rate/num tracked*escaped track" to calculate the mass flow rate of outlet in the end.
Doesn't very sure that this method is right or not.
Another question here.Sorry for disturbing you again.
I change different value of total flow rate,but the num of escaped track didn't have any difference.
Is this a regular result? Thank you so much always.
