Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Evanescent Mode Waveguide Simulation in HFSS › Reply To: Evanescent Mode Waveguide Simulation in HFSS
March 12, 2024 at 3:50 am
Hi,Â
I personally don't like to use modes in waveports that are below the cutoff frequency. You can test if they can be de-embedded correctly. Also note that to get S-parameters that one expect to see below the cutoff frequency without renormalizing waveports, you need to switch to Power definition of S-parameters. If possible, re-formulate the design so the lumped port is used.
