March 11, 2024 at 5:26 pm
Ahmed Hussien
The "DEFINE_SR_RATE" defines the surface reaction rate between two species within the same phase. Your problem is more complicated as it involves different phases. In your case, I would suggest using "Define_Source" where you define the mass source for each phase based on the mass transfer mechanism. I am not sure about the exact implementation as it should depend on your chemical resctions. Â
