Ansys Learning Forum Forums Discuss Simulation General Mechanical MAPDL convection load with variable film coefficient and bulk temperature Reply To: MAPDL convection load with variable film coefficient and bulk temperature
Francesco Miccoli
Thank you for the reply. Unfortunately the results still do not make sense.
Consider that the defined film coefficient I defined (bartz) has a peak for a value of X of around 0.5 of the total lenght, the same goes for the bulk temperature (bulk). With this input data I would expect the peak temperature to be at around 0.5 of the lenght and drop significantly after that, but the result I get is very incosistent with this. For this reason I think there is some problem with the definition of either the loads or of the TABLEs.
