Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Exporting .cdat and .cas files using TUI › Reply To: Exporting .cdat and .cas files using TUI
March 11, 2024 at 9:56 am
If there's no change to the mesh that's normal, if you're changing mesh I'd always save case & data (not cdat) too. cdat is a cut down format too, so you can't restart a Fluent run with one.Â
