Ansys Learning Forum Forums Discuss Simulation 3D Design slow printing with spaceclaim Reply To: slow printing with spaceclaim
Devendra Badgujar
Ask them to try this solution to see if that helps:
Try resetting your options. These are kept in place even when uninstalling.
Go to File > SpaceClaim Options > Advanced > Reset All User Settings.
Try Deleting the contents of %appdata%\Local\SpaceClaim.
Other work around is to use Print to PDF from the SpaceClaim printing options, export a PDF, then print from Adobe Reader.
DevendraÂ
