Ansys Learning Forum Forums Discuss Simulation General Mechanical Composite Pressure Vessel Reply To: Composite Pressure Vessel
Reno Genest
Hello Chirag,
As my colleague Zoi explained, you can model the liner as a layer in ACP or as an extra Mechanical Model system. Here is a video with the Mechanical Model approach:
https://www.youtube.com/watch?v=gL1bEdlAifM
One third party tool for filament winding is CADWIND.
You will find an on-demand webinar on pressure vessel with Ansys and CADWIND here:
https://www.ansys.com/events/composites-webinar-series
If you don't use a third party tool, the way to model filament wound cylinders is by using lookup tables in ACP. The lookup table is used to specify the thickness and fiber angle for different X, Y, Z locations on the cylinder (pressure vessel). You will find more information in the following posts:
/forum/forums/topic/filament-winding-simulation-in-ansys-composites-prepost/
/forum/forums/topic/lookup-table-ansys-composite-prepostansys-acp/
Let me know how it goes.
Reno.
