Ansys Learning Forum Forums Discuss Simulation Photonics How to set the boundry condition? Reply To: How to set the boundry condition?
Amrita Pati
I believe the symmteric and anti-symmetric BCs are not recognized by GPU at the moment. So, you should see the same results (same simulation volume) if you run a simulation with and without symmteric BCs on GPU. In other words, there is no advantage of using the symmetry conditions.
But you should be able to see results (same as PML) when you use them. Would you be able to copy and paste the log file for both the cases on GPU here? The log file is stored in the same directory where the simulation file is stored. It has the name filename_p0.log.
Amrita
