Ming Loon Lee
Hi Armin, thanks for your reply. i apply a displacement on top of the box and a fixed support at the base. Yes, the layers are all in bonded contact. The displacement speed in the experiment is 100mm/min, how should i input that in the analysis? And also is it because the material properties defined are all from tensile test data and not compression. Because the outer layer is a type of nylon fabric.
If so, is it possible to input two types of data (tension and compression) to define the material? The final objective is to perform the drop test model and the purpose of this compression test is to verify that model. Here is a picture of the drop test model.
