Ansys Learning Forum Forums Discuss Simulation General Mechanical Reference temperature for thermal expansion coefficient differs… Reply To: Reference temperature for thermal expansion coefficient differs…
Aurojyoti Prusty
The convergence issue can be due to various issue, not limited to this warning.
The zero thermal-strain reference temperature in Engineering Data will be the reference temperature. This may differ from the other two temperature reference input in the tree outline and for each body parts.
ANSYS modifies your other reference temperatures with respect to the zero thermal-strain reference temperature in Engineering Data and modifies the SCTE curve accordingly corresponding to that material (or the global the reference temperature). This is done by using the MPAMOD command internally.
You can check after giving the reference temperature in body same as in the engineering Data.
You can see a similar discussion on the below link:
/forum/forums/topic/error-during-static-structural-analysis/
I hope this helps!
Thank you.
Aurojyoti
