Ansys Learning Forum Forums Discuss Simulation Fluids turbulent +laminar in an heat exchanger 2 channel Reply To: turbulent +laminar in an heat exchanger 2 channel
It's a switch that you need to make. If you run a zone as turbulent that's more-or-less laminar the result may not be as accurate, typically you may see more diffusion in a result.Â
