Ansys Learning Forum Forums Discuss Simulation General Mechanical Large deflection convergence problem Reply To: Large deflection convergence problem
Marcin Nowak
I putted all the settings that you proposed, firstly separately, then all them together, and I dont get convergence. Still standard error "The solver engine was unable to converge ...". I get effect presented on the screens below. The force convergence is not obtained, displacement on the other hand is. I created the Result trackers, for the node in the inside and outside of the cyllinder. The location 'inside' is diverging (ups and downs) during the last steps. The location 'outside' is stable. The timestep at the end of solving is very low.
