Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Undetected contacts › Reply To: Undetected contacts
March 6, 2024 at 11:38 am
Turn on Large Deflection and work through the issues it causes.
A hyperelastic material model will converge more easily than a linear elastic material with a high Poisson’s Ratio. Learn how to turn on the mixed u-P element formulation using a Keyop when you switch to this model.
A small blend on the tips of the seal may be helpful to avoid element distortion when contact is working and may help the contact algorithm as well.
