Ansys Learning Forum Forums Discuss Simulation LS Dyna FSI using ALE Reply To: FSI using ALE
Ian Do
ALE is a hydrocode, meaning it is designed for high gradients problems mostly. Sometimes it can be used with lower P problems, but plate to air or aerodynamics effects is not its intended use. If you have not used ALE in LS-DYNA before you should at least attend the Comprehensive ALE seminar first before first use.
If the plate slows down a lot then your mat data (too light or too heavy mat?) or BC's/IC's may be incorrect. The required KWs are the set that define the ALE mats and their interactions with the LAG structures.  The coupling KW is ALE_STRUCTURED_FSI (for S-ALE solver, recommended) or CONSTRAINED_LAGRANGE_IN_SOLID (for older ALE solver).
Pls watch the seminar on ALH before trying to model ALE FSI.Â
