Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Exporting a large number of data sets into TXT from varFDTD › Reply To: Exporting a large number of data sets into TXT from varFDTD
March 5, 2024 at 8:49 pm
Simple methods to save data into a file are:
matlabsave in .mat format;matlabsave - Script command
savedata in ldf format savedata - Script command
If you really want to save data in txt format, you will need to specify the data, eg
write(fileName, num2str(data.E(i,j,k,m)), "overwrite");
or one line have all the data along one axis, say x (which has fewer data):
write(fileName, num2str(data.E(1:nx,j,k,m)),"overwrite");
where
x=data.x;
nx=length(x)
I strongly suggest to use the standard, simple methods to save and load the data instead of txt format.
