March 5, 2024 at 4:26 pm
deepesh.p.gurdasani
Thanks. got your point.Â
1) Also, if any singularity occurs in the above design you mentioned (Assume a singularity occurs), is there any way to remove it ? any step by step guidance to try to remove it? like adding fillet or something like that.
2) suppose I get 50 Mpa stress without using convergence option and after using convergence option, I get to know that its a singularity, do I need to ignore this 50 M Pa as wrong value or it can be considered ?
Thanks
