Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Update failed for the Solution component in Fluent. Update Solution Failed › Reply To: Update failed for the Solution component in Fluent. Update Solution Failed
March 5, 2024 at 6:27 am
when i load the case and data file to the fluent tab, should i click the yes about the data interpolation option? if it is,, then how do i next step?
