Ansys Learning Forum Forums Discuss Simulation Fluids Intercambiador de calor Reply To: Intercambiador de calor
Federico
Hello Manuel,
you will need to make sure your solution converges before comparing your results with experimental data.
See the link below on some general strategies to help with convergence for heat transfer problems.
What are the suggested steps if I am having convergence issues for conjugate heat transfer problems? - Ansys Knowledge
