Ansys Learning Forum Forums Discuss Simulation LS Dyna ASCII files not being created – Toyota THUMS v7 – MPP Reply To: ASCII files not being created – Toyota THUMS v7 – MPP
gdickey2
Hello Andres,
Thank you for your detailed reply. So if I am understanding you correctly, I need to adjust the Binary option in the ASCII keyword setup to be for EQ.2 since I am now using MPP. Did I understand that correctly? And then once I have done that and run the simulation, I can then load the *elout and others like *rcforce by loading the 'Binout' option in the ASCII in LsPrePost?
Currently, I have been using EQ.3 which did not allow for me to see any sort of Binout option, however I did have those binoutyyyy files (2 of them) as you mentioned but no way to open them. I am assuming this is because I was supposed to use EQ.2?
Thank you, Grant.
