Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How is the characteristic length of open channel flow calculated? › Reply To: How is the characteristic length of open channel flow calculated?
February 12, 2024 at 10:23 am
In much the same way as it's calculated in any other model. However, y+ is very much not the only criteria to worry about hence my comment. Depending on what the open channel is you may also want to think about how wall roughness interacts with the near wall cell.Â
I'll also remind you about the T&Cs. Specifically sections regarding politeness. Written language is often misunderstood, so extra care should always be taken.Â
