Ansys Learning Forum Forums Installation and Licensing Ansys Products Making an output parameter an input parameter in the next design point Reply To: Making an output parameter an input parameter in the next design point
Profiles can be used to transfer the data from one model to another, but in this case you'll need to take care to adjust the position of the profile: ie the x, y, and z coordinates will need adjusting.
Periodic flow is another consideration, please read the limitations in both flow and energy sections of the Fluent User's Guide.Â
