Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Writing and reading profiles in Fluent › Reply To: Writing and reading profiles in Fluent
February 2, 2024 at 2:06 am
Thanks, I'll try. But again, I say the necessary surfaces are in the INTERFACE section in Fluent. There is no such option to set reading parameters.
Another question. How will it work both files?
1.Runned the first calculation, the file was written. Stopped the calculation.
2.Enabled the recorded file for reading. I started the calculation again. Will the first file be read and written again to the first file at the same time? Or, on the second start, do you need to assign a new file to write to, so that the first one is read and written to the new one? The next round is the same again.
