Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to add a ferrite material to Maxwell › Reply To: How to add a ferrite material to Maxwell
February 1, 2024 at 3:59 pm
Hi Nick,
In your material properties you are introducing two curves, one at 50kHz and another at 200kHz. The frequency range between them is very large. Usually, you should add several curves with a little frequency difference, for example 200kHz, 250kHz, 300kHz or even closer.
If you only want to use the core loss curve at 200kHz, then I would advise you to remove the 50kHz curve. In this case the blue curve will be very close to the core loss curve you introduced.
Regards. Ivonne
