Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS Dyna – can’t reach license server › Reply To: LS Dyna – can’t reach license server
January 31, 2024 at 5:28 pm
Hello Roberto,
Are you using the Ansys license and the Ansys license manager to run LS-DYNA? If so, you need to set the following environment variables on the client machine (cluster):
export LSTC_LICENSE=ansys
export ANSYSLMD_LICENSE_FILE=1055@acadlms03.ad.rmu.edu
The default port for the Ansys license is 1055.
Let me know if this helps or not.
Reno.
