Ansys Learning Forum Forums Discuss Simulation Fluids Catastrophic wrapping failures in fluent Reply To: Catastrophic wrapping failures in fluent
Federico
The FTM wrapper may require some fine tuning to ensure proper resolution of the model. You said you are using a wrapper ratio of 0.7. I would suggest trying a lower ration, while preserving the target mesh size to see if your geometry gets resolved better.
