January 30, 2024 at 1:00 pm
Rahul
You can also create a profile file from the conditions on a specified boundary or surface. For example, you can create a profile file from the outlet conditions of one case. Then you can read that profile into another case and use the outlet profile data as the inlet conditions for the new case.
You can write profile file from File → Write → Profile.
Please refer 3.6. Reading and Writing Profile Files (ansys.com) user manual.
Could you please share the tutorial you are referring to?
