Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Ansys Fluent – how to keep graphs and solution, after closing the project › Reply To: Ansys Fluent – how to keep graphs and solution, after closing the project
Hello, normally if you write both case and data, and then read the files by clicking on read and then case and data, all the saved simulation files including contours, report plots, etc., will get loaded. You just have to open the created objects from outline view and then click on Save/Display or Plot (depending on the option available for selected object).
Additionally you can also make use of write option in the report plot dialog box to write the graph information in a separate file.
Please have a look at the link of the section of Ansys Fluent User Guide given below to know more about reading and writing simulation case and data files.
3.3. Reading and Writing Case and Data Files (ansys.com)
