Ansys Learning Forum Forums Discuss Simulation Photonics Error when running a topology optimization on a cluster (Linux) Reply To: Error when running a topology optimization on a cluster (Linux)
Lito
@samupekkaojanen,
The error below, indicates that the API was not able to open/launch the Lumerical FDTD CAD/GUI, and could not find the CAD/GUI session.
lumapi.LumApiError: 'Exception [::appOpened]: Session not found'
Are you running CAD jobs (scripts/API) on a headless cluster? You can set the environment variable below on the 2023R2 and newer releases, prior to running the API/script, if you are not using virtual display (Xvfb);
export QT_QPA_PLATFORM=offscreen
Then set lumapi to "hide" the CAD/GUI session:
lumapi.FDTD(hide=True)
See our KB for details: > Running CAD jobs on headless Linux systems – Ansys Optics
Hope this helps.Â
