Ansys Learning Forum Forums Discuss Simulation Fluids Particles didn’t show up when using the DPM volume injection Reply To: Particles didn’t show up when using the DPM volume injection
Bill Hsu
Thanks for your suggestion again!  I had exported the particle track data (variables: particle diameter, particle velocity ) from fluent and imported the data into the CFD post. however, when I set up the contour, there's no option for the DPM variables. I think the reason why the DPM variables didn't show up is because my assumption is one-way coupling?  But my case should be done in one-way coupling, is there any method to show the DPM varables without enable the "interaction with continous phase"? So far I know the DPM concentration can be plot by using UDF in one-way coupling, but I'm wondering for the particle diameter or particle velocity if there's any more efficient way to show them.
