Ansys Learning Forum Forums Discuss Simulation General Mechanical Transient or Explicit for high strain rate simulation Reply To: Transient or Explicit for high strain rate simulation
Pranshu Kharbanda
Hi Ram,
I have shown below the input loading which is in the form of sawtooth displacement (displacement in microns). You may see the time where frequency here is 200 Hz (hence the time for one cycle : 1/200 = 0.005). Similarly for 150 Hz you may expect time/cycle to be 1/150s. I understand that the computing framework will change, but unable to comprehend if there will be any difference in terms of accuracy. Thanks
