Ansys Learning Forum Forums Discuss Simulation Electronics Difference between Mag_B and Mag(Real(Bx,By,Bz)) in ANSYS Maxwell Calculator? Reply To: Difference between Mag_B and Mag(Real(Bx,By,Bz)) in ANSYS Maxwell Calculator?
HDLI
Hello Krisha,
      Mag(Real(Bx,By,Bz)) will give you the magnitude of real part. With this, I do not think we could get a accurate result on your fliud calculation.
       Do you use Ansys Fluent to simulate the fluid flow under the influence of Lorentz force?  If Yes, Fluent has magnetic solver, so we need to export real and imaginery parts of Bx, By, Bz for each element. After that, Fluent could use them to calculate Lorentz force.
HDLI
