BALAMUGESH M
hi,
i am working on creep analysis project. in that i need to benchmark primary and secondary creep strain values with ANSYS creep results. i have inputs like time dependent creep strain values, deflection and constant stress and temperature. so how can i proceed with this and how can i benchmark the data.
(Kind note: Actually, i tried modified time hardening and generalized exponential models for primary creep data in ANSYS. where in these models the deformation is less comparative to experimental value. and result is not converging. what should i change what should i include any recommendations
the input data are only for one experiment result, after this benchmark i need to fins creep failure stress and time i,e tertiary creep(if anyone know that kindly give some info))
